EE Roaming - Unable to make ir receive calls when roaming
RajanM
Unable to make ir receive calls when roaming. Tried all options i.e. increasing the spend cap, changing Network Manually. Disabling WiFi calling ☹️
1 ACCEPTED SOLUTION
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
@RajanM   Did you text ROAMING to 150 before you left the UK to have roaming enabled on your account?   Does the device show it’s connected to a network ?
