Cell phone service
Kettlewell1
No service abroad
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
Kettlewell1
@Kettlewell1    Do mean mobile phone insurance?or an actual phone cover as in a phone case ?
Katie_J
Good morning @Kettlewell1
Thanks for coming here.
Did you activate roaming before leaving the UK?
Are you currently roaming outside of Europe?
Finally, could you please confirm if you received a welcome text when you arrived?
Speak soon,
Katie 🙂
