04-08-2025 08:32 PM
My phone isn’t allowing me to make calls or texts aboard. When I do it says sorry or she will not allow this call. Please try 470. Tired that again same message even when I call 150 or 360 nothing is being allowed
04-08-2025 09:06 PM
You didn't mention this in your first post, it alters the situation fundamentally.
Phones that have been suspended for non-payment are usually restored within 24hours of payment being made. This assumes your phone worked abroad prior to be suspended, if not the advice in my previous post stands.
04-08-2025 08:37 PM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
04-08-2025 08:42 PM
My account was suspended due to a missed payment when I got the cut off today as I was working this morning and didn’t see I was cut off until I finished work I couldn’t use my phone after this! I’m sure I have unlimited data roaming aboard as I had used this before.
how do I make calls when it’s saying restricted and can’t contact EE on any numbers
04-08-2025 09:06 PM
