Re: How to retrieve an old mobile telephone number
devanshanand354
Hi i have this issue as well, i topped up 2 days ago and support said it reactivated my number, and yesterday they said i was able to order a new sim which i did and i have not gotten any notification about it.
Today i contacted support again and now they say theres no account linked to my email, Ive already added £5 how is this possible?
14 REPLIES 14
@devanshanand354 : Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
I topped it up with £5 2 days ago
i accidentally pressed solution my bad
Yes, but it had probably already gone into hibernation.
I only used the number 3 - 4 Months ago how would that be possible then?
and can i recover it?
What did you use the number for, specifically? Was this a chargeable action, such as a chargeable call or text?
If it is <9months from the last chargeable action, then CS can reactivate it by you calling them.
devanshanand354
I did that and they said they were able to reactivate the number
Leanne_T
Hi @devanshanand354
Is the number reinstated now for you and working for calls, texts and data?
Leanne 🙂
Ive contacted support about ordering a new sim card as mines been broken, and i have not gotten any confirmation of it happening. I messaged them 2 days ago and i have not gotten any updates
