Highlighted
Ee perk issues
How does ee sort out ee perk account issues. I have called a number of times now and no one can resolve. Tried to register and account now deactivated.... Have spoken to my hr dept and they have no idea about anything to do with ee perk even though as a company I have been told that we get discount.  Have tried everything I have been advised but nothing works. 02 and Vodafone are far easier to sort.. They mey be an option...
Highlighted
Solution
Re: Ee perk issues
Hi @Philohare1
Welcome to the community.
How far are you getting when trying to claim the Perk code? Have you managed to register for the EE Perk portal?
18 REPLIES 18
Highlighted
Re: Ee perk issues
Highlighted
Solution
Re: Ee perk issues
Hi @Philohare1
Highlighted
Re: Ee perk issues
Yes registered OK, then email sent to work where I had to validate. Then it all went downhill so from there.. Tried password reset etc but nothing worked and no one from ee so far has any idea how to resolve.
Highlighted
Re: Ee perk issues
Thanks @Philohare1
I've sent you a private message to get some more information from you.
Please have a look and get back to me.
Highlighted
Re: Ee perk issues
Hi Chris,
I am having exactly the same issues as above - have registered for account, received email at work however due to not being in work for a few weeks the account was deactivated and now can not log in nor will it let me re-register for a new account as says I have already registered!! Stuck in a circle... I have phoned customer services who said they could not do anything and to go into a store. I have been into a store who said they had nothing to do with it and to phone customer services.... It feels ridiculous that no one is able to help solve this issue. About to consider EE broadband too but your customer service just doesn't seem to want to help. Are you able to help please?
Highlighted
Re: Ee perk issues
Good Morning @AC100
Have you tried registering with your personal email and then uploading a photo of your work ID?
Speak soon,
Katie 🙂
Highlighted
Re: Ee perk issues
Yes I have, and again it says the login in details supplied are invalid.
Anna
Highlighted
Re: Ee perk issues
Thanks for confirming @AC100
I have sent you a private message, please take a look and get back to me.
Katie
Highlighted
New Member
Re: Ee perk issuese problem
when i login it says account deactivated
Highlighted
Hi @ahmadm
I should be able to help you get this sorted. I've sent you a private message to get some information from you.
Highlighted
by Investigator
Re: Ee perk issues
Good afternoon
I am also having trouble logging onto the perks page. again it keeps coming up user name or password invalid and if i try to register then it tells me i have already registered. I registered 2 years ago to get the codes, i have 3 phones on my account 1 has just been replaces and the lady just applied the code for me but i still need to upgrade my other 2 phones. I don't understand as i'm logged onto your EE Site on my account and yet it still comes up with user name or password incorrect when i try the EE perks Link?
I don't have ant cookies or anything on my pc that's blocking me from getting onto your site.
Happy for support please on this issue
Highlighted
Re: Ee perk issues
Hi there @dunbarcox
Are you using your work email to log into the EE Perk portal?
If so, have you selected the reset password option?
Speak soon 🙂
Highlighted
by Investigator
Re: Ee perk issues
Good Morning
Thanks for your quick response. Our work emails can now only be accessed through our own personal email account so I have to login through myself then gives me the option to access our company work email. So not sure what to do with and how as i cant get onto the work email directly from a login
Highlighted
by Investigator
Re: EE perk issues
Good Morning
Highlighted
Re: EE perk issues
Hi @dunbarcox
Thanks for coming back to me.
Have you tried logging into your EE Perk account with your work email address?
This would be using your work email that you registered as the email username when you go to sign in here.
Highlighted
by Investigator
Re: EE perk issues
Good Morning Leanne
Thanks for getting back to me. The problem i have is our Work/ station email account still works but has to be accessed through our own personal account where there is a link to the work email. So what i'm trying to say is there is no direct Link to the work email address that i registered it with without going through my own work email address first.
Hope this explains with what i'm having issues with.
Highlighted
by Investigator
Re: EE perk issues
Hi Leanne
Thanks i managed to reset my password and now have it
Regards
Dunbarcox
Highlighted
Re: EE perk issues
Brilliant @dunbarcox
Do you now have access to your EE Perk codes?
Leanne 🙂
