29-04-2022 02:23 PM
Hi
I have a data fixed add on of 160g but have an offer for £10.62 for unlimited data, it says that if I take the offer it will remove any other on data I have so Im not paying for anything I dont need, will it remove the fixed add on??
29-04-2022 04:26 PM - edited 29-04-2022 04:28 PM
Do you mean you have a Pay Monthly Plan with 160gb of Data?, if so, then the Unlimited Data Add On will replace your current Monthly Data Allowance, so the Ongoing Cost will be £ Existing Plan Cost + £ 10.62 UL Data Add On.
29-04-2022 04:30 PM
Thankyou 👍👍
29-04-2022 04:36 PM
You need to do the Maths, as it could be cheaper to a UL Data Plan Upgrade, especially if it's a SIM Only Plan.
