Roaming data missing from contract
Lfirman15
Why has data roaming dropped of when I haven't changed contracts?
What makes you think data roaming has dropped off your contract?
An explanation of your symptoms may well help advise. Are you currently abroad and having problems using mobile data?
Its no longer included on my acvount
Sent from Outlook for Android<>
Was this the Roam Abroad Pass as an Inclusive Extra?
If so, it has been removed as a result of changes published and implemented from the 4th of December, you can read more here: https://community.ee.co.uk/t5/Roaming/Roaming-refresh/m-p/1480939/highlight/true#M3367
The change took place in December and the old passes have been going through the process of being changed and removed since.
You will now have the choice to choose EU Roaming or Roaming Pass ROW (Covers Zone 1 countries) as an Inclusive Extra if you currently are on an All Rounder or Full Works plan taken before 29th August 2024.
Info can be found on here on the new Zone-based system: ee.co.uk/roamingrefresh
Suspected as much. Unless you're specifically talking about a "Travel data pass", then the chances are the add-on you have/had, was not a "data roaming" add-on as a "roaming" add-on that covers voice calls, text messages & mobile data.
The reply from Matt_124 makes some very good points - further clarification from you on the specific bundle, may help.
