07-09-2022 06:53 PM
It says ps5 are in stock but i cant do them on the website, what would you advise
07-09-2022 07:58 PM
@MattyLeeT18 Are you a EE mobile/tablet contract customer within the first 17 months of that contract? If the answer no to any of that then you can not order via the add to plan store.
07-09-2022 08:29 PM
Yes
07-09-2022 08:33 PM
@MattyLeeT18 how long have you been an EE customer for ? You have to be over 30 days before you can use the add to plan store.
08-09-2022 12:06 AM - edited 08-09-2022 12:06 AM
I've being a customer over 30 days but still within the 11 months, is anyone able to do a stock check
08-09-2022 12:28 AM
The website tells me to login now when im logged in then when i do it shows up as 0 add to pan acessories
08-09-2022 08:37 AM
Hi @MattyLeeT18
It may be worth speaking to our Mobile Care team so they can check your eligibility and try to put the order through with you.
