24-05-2022 06:27 PM
Why is my code not working
25-05-2022 07:43 AM
Hi @Loulou39
Welcome to the community. We'll do our best to help you.
Which plan and phone are you looking at? What happens when you try to use the code?
25-05-2022 05:40 PM
It is an I phone 13 pro took the contract on Saturday gone and was told you have 30 days to redeem your code phoned up with code and was told its not supported ,when I searched its seems most peoples codes do not work
26-05-2022 07:40 AM
Hi @Loulou39
The Perk discount code should be given at the start of the contract. This ensures that it's compatible with the phone and plan that you're choosing.
I've sent you a private message to get some information from you. We'll do our best to get this sorted for you.
