using phone in Turkey
Jimitheweave
I'm travelling to Turkey. If I set up call forwarding for all incoming calls to a UK landline number, will I be charged?
@Jimitheweave : As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/turkeyandnortherncyprus.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
If your divert is an "unconditional" divert all, incoming calls won't leave the UK and you won't be charged.
