roaming abroad
High5hully
I am struggling to access my roaming that I purchased as an add on, im currently away but cant even send texts to ee to see of its activated what can I do.
Debbie_G
Hi @High5hully
Did you activate roaming on your account before travelling?
Debbie 🙂
@High5hully : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
