on 29-05-2023 06:37 PM
Will I be charged Roaming Charges in the Netherlands, if I have a sim free monthly contract with EE
Sent
Solved! Go to Solution.
on 29-05-2023 07:08 PM
@Michael251 : Yes, if you took your contract out after 07/07/21.
You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.29 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £15 / month. There are no extra roaming charges for PAYG until 6th June.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
