22-03-2021 10:42 AM
I have switched to Pay as you go today and my calls are diverted to my voicemail, what do i need to do?
My credit is 0 and I'm using a Samsung Galaxy S10+
22-03-2021 10:54 AM
Hello @alexsampler
Are you in the UK or abroad?
All new EE PAYG SIMs need to be activated on EE's UK network first, and this includes migrations from pay-monthly.
If you are currently abroad, your "new" PAYG SIM will not work until it is used in the UK first.
22-03-2021 11:09 AM
Hi @bristolian,
I'm not in the UK, I'm in Italy and i can't go back to the UK at the moment.
What can i do for it? There's any way to unlock this?
22-03-2021 11:43 AM
Unfortunately there is no workaround here.
Your SIM will need to be used in the UK first, before it will work abroad.
If a friend or relative has access to your UK address, you could report your current SIM lost/stolen which would enable a replacement to be sent there. Your contact could then activate it in the UK before posting it back to you.
You should also be aware of the PAYG hibernation policy - you will need to use this SIM within 179 days of the migration else it will be hibernated.
