20-05-2023 10:05 PM
Hi, I checked roaming settings before travelling and thought that all was setup.
I’m now in Portugal and I’m not able to use data or other services. Have checked my account and set a spending cap of £30, checked roaming via 150 and all appears to be setup. But it’s still not working.
any ideas?
Thanks.
23-05-2023 06:07 PM
Seems that having the spend cap set was causing a block on roaming!! CS removed this and all works fine. Very odd !
21-05-2023 06:57 AM
Thanks for coming here.
Do you have signal?
What happens if you manually search for a network, do any show available?
Leanne 🙂
23-05-2023 06:07 PM
23-05-2023 06:27 PM
Thanks for coming back to share the solution with us, @SteveAlexander
Enjoy the rest of your trip. 🙂
