Roaming in Japan
ASM666
I'm wanting to receive text messages in Japan. I've arrived and roaming seems to be on, data off, connected to WiFi but nothing coming through
7 REPLIES 7
ASM666
Been playing around with networks and don't seem to be able to connect to any
James_B
EE Community Manager
Hi @ASM666,
Did you text ROAMING to 150 to activate roaming before you travelled?
Thanks. No but I've used it in the past and I didn't before going to France last year when it worked fine
What's your basis for thinking that "roaming seems to be on" - does your phone show signal indicators of a Japanese network?
This is an account-level function which enables your phone to connect to foreign networks, and would have been enabled by texting ROAMING as advised above.
WiFi-calling isn't supported abroad.
ASM666
Thanks. Sounds from advice above that I should text roaming each time I go abroad even though the EE website doesn't suggest it is necessary.
IJMG
 Hi - I'm in Singapore and have paid for a 7 day package for 300 MG of data. But after 6 hours still saying 'waiting'. Any way I can get the data I paid for?
Christopher_G
Hi @IJMG
Welcome to the community
Does your phone have a signal? Are you able to make calls and send texts?
