08-05-2021 05:30 PM
For some time our 2 phones have used the best signal at the place we stay at in France.
Now they are choosing Bouygues even though that is the worst (and at times no bars just the R) signal. Manually choosing another provider like SFR Orange or Free works for a short while then they go back to Bouygues.
Is this being controlled from EE and can it be changed?
09-05-2021 08:25 AM
Hi @nmh42
This would be the device that is picking up the network, do you have automatic network selection turned on in your settings?
You can find help in our EE Roaming - Help when abroad with your EE phone or device, post.
Thanks.
09-05-2021 08:32 AM
Hi Leanne
Thanks for your reply.
We have tried Auto and Manual selection, restarted the phones, swapped the SIMs, etc etc. It seems like Bouygues signal has priority (no matter what its signal state) over other networks which have full signal. The real question is whether this is as you say the devices, the networks here or whether EE can change this apparent bias via our SIMs?
09-05-2021 08:43 AM
@nmh42 EE can not force your device to use a different network. Have your tried switching off 4G ?
09-05-2021 08:59 AM
Hi thanks for that info. If that is the case it must be a change in the networks here I guess. (One phone is not 4G and the other does not use 4G as its an old SIM.)
I will keep trying manual and auto settings but for now I think its beyond our control, my only angle was whether EE could influence the network priority.
Thanks for your input (and to Leanne from earlier)
best regards Neil
09-05-2021 10:56 AM
When you're using auto network selection, there are numerous criteria that dictate which network or coverage layer your phone connects to. From time-to-time, certain foreign networks can have higher priorities in particular circumstances.
In your case I would recommend reporting this to EE via C/S on 150. If you're calling within the EU, using the international number is free as per this help page
09-05-2021 11:48 AM
Many thanks for the advice and link. I thought there might be an easy answer without getting involved in an investigation as such but will bear it mind thanks.
best regards Neil
10-05-2021 08:03 AM
Just tried a test.....placed phone where I know Orange and SFR signal are excellent and Bouygues is really weak. Manual search lists Bouygues first, Auto goes to Bouygues. There is surely some priority being imposed for (or by?) Bougues??
