17-03-2021 08:20 AM
Hi, I am due an upgrade and I am looking at the 120GB plan. Is that 120GB a month for £20? And also I am currently stuck in Bulgaria and been using my phone with no problem, would there be any changes if I change my plan and post-Brexit?
17-03-2021 08:31 AM
Hi @andrewbond28 and welcome to the community
There's a couple of different angles to this...
1: Your upgrade options will still remain open to you after you return to the UK, being entitled to an upgrade now doesn't mean you must take that option up if you'd rather wait.
2: Brexit and roaming, is completely immaterial to what is, basically, a change of payment plan which is normally immediate (if you call in) or activated within a day or so (if you do the process online)
I presume by "upgrade", you're referring to a change to/of a SIM-only plan? If you're referring to the purchase of a new phone or device, that will only be delivered to your UK billing address.
