on 26-04-2024 08:38 PM
I’ve had the same. Code is 85058 which says invalid when I checked. How can I find the company that kept charging me 19p, several times a day with some at the exact same time?
Solved! Go to Solution.
26-04-2024 10:12 PM - edited 26-04-2024 10:14 PM
@AuntieAndy : GIYF > BBC Radio 5
85058
If you're texting us on 85058, you will be charged at your standard message rate for each message.
85058
on 27-04-2024 04:12 AM
Got it doh. I realise now it was for a text. Cheers.
on 27-04-2024 12:22 PM
