Re: Roaming charges
cberrie
Hi! I am currently in Sweden right now thinking about to get the roaming pass. I have already spent £4 (2days x£2). If I activate the abroad pass now and turn it off when I get back to UK next week will I only be billed for the days I have used it? or is it for the full 30 days?
Katie_B
Hello @cberrie
If you activate the Roaming Pass for £10 you will be charged the full amount.
Katie 🙂
Thanks for the quick reply! If I activate it today will EE stop charging me for the daily rate of 2 GBP starting tomorrow? Do I need to do anything to make EE stop charging me for the daily rate and instead use the roaming pass?
Katie_B
Hi @cberrie
Once you have an add-on in place which allows you to use your phone you will not be charged the standard rate of £2 per day.
I hope this helps,
Katie 🙂
but only initially. When you stop it you will be rebated for the days you didn't have it but paid for in advance. So, as @chistery said, you only pay for the days you have it
