29-03-2022 09:26 AM
Hi!
I have been in Hungary for 10 days. No data, outgoing calls or messages to England are possible !!! 150 can't be reached anywhere !!! What the **bleep** am I doing? I'm getting fed up! I have an unlimited monthly subscription.
29-03-2022 11:15 AM
If you are unable to activate this, you would need to contact us from any other phone on +44 7953966250.
29-03-2022 09:46 AM
@Belfegorka69 Have you activate roaming on your account ? The ability to use your allowances in the UK doesn’t mean your device will work abroad if roaming isn’t enabled.
29-03-2022 10:06 AM - edited 29-03-2022 10:07 AM
Morning @Belfegorka69
Thanks for coming here.
Can you try checking your roaming status by logging into your My EE account online go to Menu > Account Settings > Parental and Data Controls > Enable Roaming and also Make calls abroad from the UK, do they show as ticked?
Thanks.
29-03-2022 10:23 AM
I checked everything ... I don't want to call from the UK, but to the UK !!! I can't send a message to 150! Everything is forbidden
29-03-2022 10:28 AM - edited 29-03-2022 10:36 AM
I texted Roaming to 150 and go that back (this was done months ago, I just wanted to check)
Setting up roaming is very inconsistent, you get different errors or messages depending where you look! You can never be positive it’s on.
But this has always been off on the EE account settings and trying to turn it on results in an error
29-03-2022 10:33 AM
To make calls from abroad you would need this setting active, are both showing as ticked?
29-03-2022 10:51 AM
all allowed only outgoing calls from england can't be resolved .. and if i have to buy any extra packages, i don't see an option anywhere where and how to do this.
29-03-2022 10:56 AM
Just to confirm, both the above options show as ticked in your My EE account or just roaming?
What happens when you try and make a call?
29-03-2022 11:07 AM
only outgoing calls from the UK are red. Nothing happens when you make a call. Message failed. When calling 150, a machine voice announces: disabled!
29-03-2022 11:15 AM
