06-03-2022 09:44 AM
Is there any way to get missed call alerts working with visual voicemail? They work with normal voicemail but not with visual VM. I presume this is because the alert is generated from VM itself. I have toggled it on and off in the VM settings but it doesn’t work.
Any suggestions?
06-03-2022 12:58 PM
Hi @Dryroasted.
Welcome to the community.
What happens when you miss a call, do you not get a notification?
What phone are you using?
Jon
06-03-2022 04:54 PM
No not if I use visual voicemail but it works with normal voicemail.
I am using an iPhone 13 pro.
Cheers
Paul
07-03-2022 07:57 AM
Hi @Dryroasted
Try resetting your network settings:
Tap Settings > General > Reset > Reset Network Settings > Follow the prompts.
If you still aren't getting notifications, it may be worth speaking to our Technical Support team so they can look into this for you.
