on 17-11-2022 11:01 AM
Hello there
I’m in Nairobi and can’t get any connection to make calls or get taxi. I can’t can’t text travel to 150 as no network.
I'm using wifi at a shop just now but can’t call ee over wifi to get help.
I am worried now I won’t be able to get anywhere and so will have to head back to the airport to seek help.
can anyone advise what to do if I’m in a Kenya and no network.
does EE have a messaging platform to contact them in emergencies
many thanks, Paul
on 17-11-2022 11:07 AM
@Cal1972 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
on 15-06-2023 11:43 AM
Can you please check it and let me know how long it’s takes to activate my sim ?
on 15-06-2023 12:05 PM
Hi @vishal007daman,
Is this a new SIM or a replacement?
Are you in the UK or roaming?
Is it pay as you go or pay monthly?
