21-01-2021 01:39 PM - edited 21-01-2021 02:16 PM
I'm currently in Poland. Of course I can not send text to 150, as roaming do not work. Is there any change to activate roaming when I'm abroad?
Any tips?
21-01-2021 01:45 PM
Hello @mateusz4.
Are you pay as you go or pay monthly?
Pay monthly roaming can be activated within your My EE under account settings.
Katie 🙂
21-01-2021 01:50 PM
Hello,
I'm with plan: pay as you go.
21-01-2021 01:53 PM
Hi @mateusz4.
Pay as you go roaming is automatically enabled.
Have you activated and used your SIM successfully in the UK before travelling abroad?
Katie 🙂
21-01-2021 02:00 PM
Yes, I used SIM card without problem in UK.
In fact phone is logging into Polish network (4G), but I can't send text, make call or use data.
In phone setting roaming is switch on.
Also I can receive text without problem.
21-01-2021 02:32 PM
21-01-2021 02:58 PM
Yes, i connected with local network.
I can answer calls from UK, but i cannot calling.
21-01-2021 03:02 PM
21-01-2021 03:04 PM
yes,
i tried a few locals network
21-01-2021 03:23 PM
