27-06-2021 05:12 PM
My account says I have £25 credit but it also says I have no messages, no minutes and no data. How can I use this credit? I am outside the UK at the moment and need to use my phone. I though i would be able to top up using this credit but it indicates it will take money out of my card and not use the credit. Urgent help required.
Regards
Andrew
27-06-2021 05:51 PM
Where are you?
27-06-2021 06:41 PM
I am in the us trying to get back to the UK.
27-06-2021 06:47 PM - edited 27-06-2021 06:50 PM
@AApsley Your credit on your account will go towards calls/text and you need to purchase a data bundle to have data in the US. If you are using packs unfortunately you can not use these in the USA. Have a look at THIS Make sure you select PAYG and you can purchase a data bundle from the bottom of that page.
27-06-2021 07:21 PM
Thank you both.
Andrew
