19-09-2021 02:17 PM
Does anyone know why 'Conditional Call forwarding active' comes up when I try to make a call?
19-09-2021 02:28 PM
Hi @Lezlee
This is device function that is advising you of a "conditional call divert" that you have set on your phone.
The usual reason is that any incoming call that you don't answer for whatever reason, is diverted to voicemail.
22-09-2021 12:02 AM
22-09-2021 03:02 AM
Hi @Lezlee
If you wish to switch voicemail off text VM OFF to 150 and it will cancel the divert to voicemail.
Thanks,
David.
22-09-2021 08:31 AM
You can only disable this popup by cancelling your voicemail diverts as has been advised above.
This will also stop your voicemail from automatically picking up any missed calls to your phone.
This notification isn't impacting the use of your phone in any other way.
