01-03-2021 09:19 PM
Hi
So I cannot quite seem to get a clear answer on this. Just curious for coursework I'm doing. It's my understanding that EE can record dates and times of calls and messages and numbers used etc. But NOT the actual contents of conversations. Is this correct?
01-03-2021 09:24 PM
Correct. They do record times & durations of outgoing calls & texts but not of incoming.
01-03-2021 09:35 PM
OK thought so. Under the privacy policy I believe SMS content basically means texts and it says these are kept for 7 days. Is this the case?
01-03-2021 09:38 PM
Hi @RG1996
Depends if you are under investigation and subject RIPA. That said the national security agencies monitor and read everything regardless of app or firmware. Read Edward Snowden book.
01-03-2021 09:40 PM
Oh well I'm definitely not was merely curious.
01-03-2021 09:41 PM
