Abroad in india , in able to connect network
KeshDr
Hi Unable to connect to any network as I am
india . Bought travel pass
Data is on roaming
auto network selection
still not working
KeshDr
Found solution, EE customer service personnel was very helpful
my tip for any one in the same boat
is to contact CS , by “web chat “ as there is no net work , the only way to contact by Chat
You can access the chat from “Contact us”
Easy, Free , with 100% Success
it May take up to 15 mins or but worth it
6 REPLIES 6
Jon_K
Former EE Employee
Thanks for coming to the community, @KeshDr.
Is roaming enabled in your My EE Account?
Jon
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
KeshDr
Leanne_T
Thanks for coming back and letting us know @KeshDr
Glad to hear this is now sorted for you 🙂
I tried the same way as I have a similar problem in India. I cannot connect at all to the India network or showing no signal. I have an India sim as well which works perfectly so it’s not my iPhone. I used the app chat and still have no reply. What can I do or is there no way to connect with EE in India?
Katie_J
Hi @DSCHART.
Welcome to the community.
Are you a pay as you go or pay monthly customer?
Speak soon,
Katie
