4G not working on roaming Pakistan
ChopraRohan
Hello I am using EE I have 5G working but 4G or 5G is not working on roaming Pakistan any solution!
9 REPLIES 9
Schockwave
Hello @ChopraRohan ,
Welcome to the community,
EE is not responsible for network connections in other countries, that would be down to the country you are in.
Have you tried a manual search to see if you get a better connection.
I take it you have roaming enabled on your account, which you should have done whilst in the UK?
Hi @Schockwave thank you for your reply, yes I try manual searching of network it will connects to only 3G networks, while connects to 4G network it doesn't connect it all new EE sims are 4G / 5G enabled?
Katie_J
Thanks for getting back to us @ChopraRohan
What network are you currently connected to?
Are you aware if anyone else is experiencing this?
Could you confirm if you activated ROAMING before leaving the UK?
Do you have a pack in place to use whilst in Pakistan?
Katie
Jazz 4G Network - Connected to Jazz 3G - 4G is forbidden in EE roaming UK
none Other UK network works fine.
Yes
Yes
Katie_J
Hi @ChopraRohan
Are you able to make calls and texts OK?
Katie
yes I can but 4G roaming is not turning on is 4G+ roaming is giving 4G net provider at EE to there?
Katie_J
If you are able to make calls and have a pack in place I would recommend getting in touch with our technical care team on +44 7953 966 250 @ChopraRohan
Alternatively, if you do not wish to call please use our live chat service which is available when logged in to your My EE account.
Katie
ok where I find the live chat option of EE
Katie_J
Hi @ChopraRohan
Once logged in an option to chat should pop up.
You could also please try visiting this page.
Katie
