Community Activity
Microsoft Teams Quality Issue
Hello all,I've got an odd issue which I'm hoping someone can offer a steer on.I have the EE 1.6 Gb Full Fibre Busiest Home package with a Smart Hub Plus.All seemed to be working fine until my original Smart Hub Plus failed in Jan 2025. This was attri...
Charged for simple text message
When you send a text message it can travel by iMessage, SMS, MMS, or RCS.The choice is down to your phone type, your phone settings, your carrier's policies, the policies of the carrier used by the recipient, and the type of phone the recipient uses....
G109B by Valued Contributor
  • 56 Views
  • 9 replies
  • 0 Helpful
Extending ringing time on Nokia 105/ non smart phone
Hi, I want to extend ringing time of my Nokia 105. It only rings twice and cut off. As my phone is not a smart phone… those number came up on Google search did not work. Is there any different way? I tried to make my voice mail back on but it is not ...
Achan1 by Investigator
  • 8 Views
  • 1 replies
  • 0 Helpful
WiFi
WiFi on my mobile works if I am at home but otherwise says not connected.  Not had this problem before.  How do I fix this please?  Mobile phone signal states good thank you for your help regards Leigh
Web Protect
Having problems connecting to web protect to turn it off. Keeps saying there is a problem and they are trying to fix it.
diabhal by Explorer
  • 36 Views
  • 5 replies
  • 0 Helpful
EE Failing Miserably in USA
After meticulously going through a process with EE to get assurance of being able to use my mobile while here in Florida EE has failed on all fronts. Other members of the family here with Vodafone have experienced NO PROBLEMS regarding and making or ...
Apple Music benefit not linking
Hi. Upgraded phone with Apple one+ including free Apple Music. Not received text yet from Apple Music (been 2 days). Set up in EE app and lost all my family sharing accounts. Had to replay Apple Music. Can’t access benefit as Apple says EE haven’t gi...
Mags51 by Investigator
  • 125 Views
  • 10 replies
  • 4 Helpful
