Texts not sending via RCS
MarkDean
But I am receiving texts via RCS.
Fixes I've tried:
- cleared Google Messages cache and data
- toggled RCS mode off and back on after 30 seconds
- made sure mobile is up to date
- restarted mobile
Also getting RCS mode hanging on verifying/connecting, as well as error codes 3000 and 4001.
Mobile is an Samsung Galaxy S24, issue started yesterday. Thanks!
Alex_H
Hi @MarkDean,
Welcome to the EE Community
 It does sound like your number registration may be stuck based on those error codes, thanks for letting us know what you have tried so far, those are steps we would usually recommend.
 If it is still not verifying the number today when you are turning it back on, try de-registering the number using the Google website and give it 24 hours before turning RCS back on for verification on the phone.
Alex
Hi Alex,
Thanks for getting back to me.
I toggled off RCS for 24 hours just in case - no change unfortunately!
On the page you linked, there's an option to verify my number with Google - but my phone hasn't been lost or stolen. I bought it in January this year and this issue has occurred randomly, it seems. Is it safe to verify my number with Google in this instance?
Thanks.
Alex_H
@MarkDean Thanks for the updates. All that does on the website is remove your number completely from RCS registration, it doesn't do anything else with your actual phone.
If turning it off and on on the phone itself is not working, that can be a workaround to remove your completely from RCS registration to then hopefully force re-verification when you next turn it back on to your phone after waiting.
Alex
No luck unfortunately. Any other potential fixes?
Thanks.
Debbie_G
Thanks for letting us know, @MarkDean
As you've tried all the usual troubleshooting steps without success, I'd recommend getting in touch with our customer service team. They'll be able to investigate this further and look into anything that may be affecting the service.
Debbie
