on 02-08-2022 01:55 PM
Currently sat at work with zero bars, does anyone know of any issues?
on 02-08-2022 03:11 PM
Hi there @Spigcore
If you use our EE Coverage & Network Status Checker, and select 'Check Status' this will show any known problems, for the area.
If none are showing select 'Report a problem' option, our network team will get this looked into and keep you updated.
Thanks.
