Signal problems
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
24-06-2023 09:17 AM
Hi, is anyone else having signal problems? Mine has been on and off the past few days. It's going from 5g to 4g to H+ to nothing at all. Its normally really good but not now. I'm in the Newcastle area.
John
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
24-06-2023 09:41 AM
Indicated coverage varying between different technologies shouldn't directly cause any concern unless it prevents use of your phone for calls, texts or mobile data. Is it?
If you're getting a total loss of coverage, is anything reported on https://coverage.ee.co.uk/coverage/ee ? Use "check status"
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-06-2023 07:01 AM
@bristolian wrote:Indicated coverage varying between different technologies shouldn't directly cause any concern unless it prevents use of your phone for calls, texts or mobile data. Is it?
I have only recently joined EE and was tearing my hair out trying to get the simto work as it would do calls but not internet. I eventually thought to check the network status as indicated above. And tyes there was an issue with expected resolution in 16 hours. However 12 hours later it says 16 hours so not sure if EE just say that for everywhere. Anyone else had that?
