Re: No network coverage!!!!!!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-07-2024 09:22 PM
Same issue for me. 3 days and no coverage still. Have you found anything else out yet?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-07-2024 12:04 AM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
