Poor network connection iphone 12
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-04-2023 05:45 PM
Got my new iPhone 12 on contract with EE. 5G but is absolutely dreadful. Husband has iPhone 7 similar package with EE but 4G and his works perfectly. Any ideas?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-04-2023 05:55 PM
What are the symptoms you're having?
The 5G network is still in relative infancy compared with the mature 4G side, so a 5G phone may have perceivably poor coverage when on the fringe of 5G service.
It shouldn't cause any issues using the phone - it should drop down to 4G as & when necessary. If that's not the case - how so?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-04-2023 06:01 PM
Hi yeah it makes no difference. Even when I go into settings and manually shift down to 4G.
Thinking I’ve got a phone that is faulty?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-04-2023 08:50 PM
Actually defo think it’s a problem with my phone. Wi-Fi connection is so unpredictable too.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-04-2023 08:49 AM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-04-2023 11:52 AM
Hiya
it varies. There are no particular hot spots as it can be very temperamental. But often my phone just freezes when I’m using Wi-Fi at home and takes ages to access the internet.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-04-2023 07:03 PM
It hates Safari internet searching Google etc. So if I’ve got Twitter, Instagram email etc which usually works anywhere using 4G. Browsing is an absolute unpredictable beast though. Even on Wi-Fi it can not work.
Di you think it’s my phone?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-04-2023 07:19 PM
@Andrea70 Sounds like a device issue . Have you tried a network reset on the device? It might be a new device but I’ve had a similar issue years ago with a new iPhone 4S and network reset fixed that issue . A network reset doesn’t just reset a cellular connection it also resets a Wi-Fi connection. Setting>General>Transfer or Reset iPhone>Reset>Reset Network Settings. If this doesn’t resolve the issue then yes you could have a faulty device.
