Find out if plan is 5G
imimayj
Hello! I was wondering how I could check whether I get 5G coverage (I just bought a new 5G ready phone) and am a monthly customer. Does anyone know how to do this please?
EssexBoyEE
You can check the 5G Coverage in your Area using EE Coverage checker -
https://coverage.ee.co.uk/coverage/ee
but as @XRaySpeX spec says you need to check if you are on a 5G Plan in order to use 5G
Do you have a 5G plan? Look at its name in your bill.
EssexBoyEE
