on 16-12-2022 08:07 AM
Hello! I can’t make outgoing calls for some reason. And incoming calls are getting dropped. Tried switching to WiFib calls but that’s not fixed the problem. How do I contact EE to resolve this? (Think they are doing work on local network). Thanks
on 16-12-2022 08:14 AM
Does your phone show coverage indicators?
If no - check for local issues using "check status" on online coverage tool
If yes - what happens when you try making a call?
on 16-12-2022 09:15 AM
I can see couple of EE bars, and have set up Wi-Fi calls. But when I call out, the phone I’m calling doesn’t ring. It’s like I’m not connecting. What’s going on?! I know EE have been working on network (in Poole, Dorset). Think I need to check it out with EE, but how? Thanks for any advice you can offer.
on 16-12-2022 09:50 AM
Hi @emilou73
Thanks for coming here.
Does this happen on all calls?
If you call 150 does the call connect?
Leanne 🙂
on 16-12-2022 10:21 AM
Yes, calling 150, call fails. Also for incoming calls, my phone rings but when I answer, the call cuts out. Can you help?
on 16-12-2022 10:24 AM
Btw checked online coverage tool, and it says no problems.
on 16-12-2022 10:34 AM
Thanks for checking @emilou73
Are you able to try the SIM Card in another phone to see if the same happens?
Leanne 🙂
on 16-12-2022 02:06 PM
I can make calls using my i watch. Why is my phone not working? Who can I contact to get this fixed? Thanks x
on 16-12-2022 02:36 PM
Hi @emilou73
Have you tried the SIM in another phone?
This will help us to see if the phone or SIM is causing this problem for you.
on 04-09-2023 07:16 PM
Yes
