2G/ 3G INTERNET CONNECTION .
g7iq
nokia 225  / on 2g/ 3g .  suddenly want connect to internet ?????.   any ideals .s-l500 (1).jpg
James_B
EE Community Manager
Hi @g7iq,
Does the Network Status Checker show any problems in your area? (Select the 'check status' option)
6 REPLIES 6
Is mobile data enabled on your phone? What happens when you try using it?
2G data will be extremely slow and only usable for the most basic of emails.
g7iq
USE to connect fine . NOW g  symbol  appears top off phone circle goes round  trys connects . After while says server error
James_B
Hi @g7iq,
g7iq
THANCKS  yes   networkissues   just checked .  CLUTTON TOWER NR BRISTOL BS39 AREA .
James_B
Hi @g7iq,
Please register for updates so we can keep you informed.
This sounds like perfectly normal behaviour when trying to load anything but the most basic text-only webpage over 2G.
With 3G being switched off, this will increasingly be usual service unless you have a 4G phone
