26-04-2024 02:52 PM
We will be travelling to Spain in a few weeks time and I will add the roaming abroad pass. Please could someone confirm if when I have texted 150 with roaming and the pass is activated what happens if I make a call from Spain to a UK number? Will I be charged or is that part of the pass? Thanks
26-04-2024 03:15 PM - edited 26-04-2024 03:17 PM
@WitchyWitch : These are 2 separate but connected things:
You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.47 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £25 / billing month.
26-04-2024 03:32 PM
- Texting ROAMING to 150 gives you the ability/permission to roam abroad. This is free.
- Texting ROAMING PASS to 150...It won't come into play unless you have carried out 1 above.
Although to add... you can easily pay for a roaming pass but find yourself without mobile coverage abroad and thus unable to use it... IF you enable the pass but don't enable roaming. That's a very common mistake, and creates a catch-22 situation.
Ensure you get text confirmation of both step-1 & step-2 above.
