data usage
knotty49
my recently started 5G mobile broadband service used to let me see how much data I had used by logging on to the router.
If I do this now I get
Forbidden
You don't have permission to access this resource.
As far as I know I haven't altered anything and this is still in the first month of use.
WHY?
7 REPLIES 7
Clear your browser's cache & cookies &/or try another browser.
Thanks but
Cache cleared
No improvement still says forbidden
Sent from Mail<> for Windows
Leanne_T
Hi @knotty49
Do you have the link saved?
Can you try opening add-on.ee.co.uk in a new web browser, does this work for you?
That doesn't work either
Leanne_T
Hi @knotty49
Thanks for trying.
Which web browser are you using?
What device are you using to access the add-on page?
Could you try a different web browser, does this work for you?
I’m using edge, using a different browser is treating the symptom not the cause.
As I don’t recall changing anything to change the browser is more trouble than its worth. However I’ll try from a tablet (using a W10 desktop) and see if that helps.
Leanne_T
Hi @knotty49
Trying this will help us to find out what could be causing this for you.
If you can try and let me know how you get on that would be great.
