09-08-2022 04:07 PM
I have a Synology RT2600 which is connected to the www via a slow FTTC connection. I would like to keep that connection as a fall over and connect the 5GEE router into the 2nd WAN port.
Can the 5GEE router be configured as a modem?
The RT2600 has a mobile dongle option but 5G compatibility is not known.
Thanks.
09-08-2022 05:33 PM
The 5GEE 2021 router cannot run as modem-only.
What acts as the modem for your FTTC BB?
09-08-2022 05:39 PM
10-08-2022 12:32 PM
Could you turn off the wifi and give it an IP such as 192.168.100.1?
10-08-2022 12:48 PM
Yes, you may turn WiFi off. You might be able to give it a fixed IP in the main router's DHCP range but not all mobile routers allow config of the DHCP.
