Sim Card
stoker-john
Hi
I was wondering if anyone can help, the company had recently purchased a sim so we can use it in our router,
unfortunately, the number associated with the sim was lost (packaging was binned by an employee). The problem is there is no phone associated with the sim as it was for a router only.
Is it a case of reordering a Sim card to replace the one we have no number for?
Any help would be greatly appreciated
cheers
@Schockwave : The serial no. isn't its mobile no.
@stoker-john : Look at http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see its mobile no. as well as  data & credit status. Alternatively look in the router's settings for its Phone no. or MSIDN.
Schockwave
Hello @stoker-john ,
Welcome to the community,
If you take the SIM card out, you will find the serial number on the card. You could put the SIM card in a phone and you should then be able to see the number associated with it.
