10-09-2021 02:41 PM
Did anyone ever reply re the correct settings to enable IPv6 on EE 4G Mobile Broadband using a TP-Link Router? I would like to enable the same so would be interested to know.
14-09-2021 01:00 PM
No problem,glad to be of help.
10-09-2021 11:15 PM
@devpete : You tried APN Protocol ="IPv6"?
13-09-2021 06:16 PM - edited 13-09-2021 06:16 PM
Thanks but where do I find this and how to change from IPv4? IPv4 is greyed out and can't be changed.
13-09-2021 07:48 PM
Is it possible to create another Profile Name with PDP Type = "IPv6" & make it default? Alternatively does the Advanced tab give you more control?
13-09-2021 08:07 PM - edited 13-09-2021 08:17 PM
You won't be able to change any APN settings if the Profile is set as the Default, so Undefault it to another profile or if none available as @XRaySpeX says Create another Profile, make your changes, then set the new one to Default then go from there.
If your Router is Network locked there's a good chance you will not be able to do the Changes on IPV Settings.
For what it's worth, EE Mobile Internet and Data don't work very well with IPV6 settings, you probably be better off leaving it on IPV4.
14-09-2021 09:06 AM
Ah then I think I won't move from IPv4 settings if IPV6 isn't good for EE Internet and data. Many thanks for that advice!
14-09-2021 01:00 PM
26-06-2022 11:26 AM
Hi can you explain how to do this on a laptop I am 72 and not good on a laptop thanks
26-06-2022 01:36 PM
Which 4 or 5G Router do you have? Make and Model Number (Model No. should be on the Label or Box)
23-05-2023 05:15 PM - edited 23-05-2023 05:16 PM
How well does EE mobile internet and data work with IPv6 settings now (I'm assuming you mean speed wise)? Is there a mobile network that does it better? thanks
