07-02-2022 05:56 PM
Hi, I have a Inhand Cellular router. I ordered a Sim card for it, but the router will not connect to the network with it. It works with a mobile phone. I used to use Three and I had no problems with their Sim card. I just put it in and it worked. Is there some special setup procedure to get them working or do I need another type of Sim card for it?
09-02-2022 01:22 AM
That's great news, glad I could help.
07-02-2022 06:00 PM
Where did you get the router?
Is it locked to Three?
07-02-2022 06:17 PM
07-02-2022 06:23 PM - edited 07-02-2022 06:33 PM
Have you checked and or changed the APN Settings for the EE Network.
I believe most of Inhand Routers are preconfigured APN Profiles for each Network but you have to select the correct Network Provider within the Admin Page.
When you say worked on Three, can you confirm Three UK.
07-02-2022 09:43 PM
I have not changed any APN profiles and it was working on Tree UK.
07-02-2022 10:08 PM
Ok, check and change the APN Profile, might still be set on Three.
08-02-2022 07:23 PM
What should the APN profile look like?
08-02-2022 07:31 PM
Name: EE Internet.
APN: everywhere.
Username: eesecure.
Password: secure.
MMS Proxy: 149.254.201.135.
MMS Port: 8080.
Authentification Type: PAP.
APN Type: internet+MMS. ( If an entry is required type a * on its own)
08-02-2022 08:30 PM
hi,
Thank you EssexBoyEE.
Got it working now.
09-02-2022 01:22 AM
