15-08-2022 12:28 PM
Got a new 4G router 4GEE_Router_V01.06 software. I cannot for the life of me get LAN2 to function or find anywhere in the documentation to help. There is a device plugged in, which is set for DHCP and will connect to other routers.Devices OK,
15-08-2022 02:59 PM
Welcome to the community.
Could you try a different device plugged in please? Or a different cable?
19-08-2022 09:28 AM
different devices/different cables -nothing works on LAN2. The router appears to be throwing connections off randomly (before the 24hr lease) so I think its the third borked new router in a row!
19-08-2022 10:34 AM
I can get LAN2 up but not when LAN1 is up!
19-08-2022 10:40 AM
It may be worth speaking to our technical support team, @holefarmhome.
Let us know what happens.
