5g router 2021 dropping Internet and then not reconnecting
Rob602
Valued Contributor
Valued Contributor
I’ve got a 5g home broadband 2021 router and it keeps losing internet but doesn’t reconnect automatically.
any ideas ?
it’s showing 5g and signal strength but won’t connect to the Internet.
a reboot gets it back but It’s not a solution
Leanne_T
Hi @Rob602
Thanks for coming here.
Do you have any other devices on EE?
How often does this happen?
Thanks.
Rob602
Valued Contributor
Valued Contributor
No other EE devices.
Every few weeks.
I work away so my wife is without internet as the router is in the attic to get a useable 5G signal and she can’t get up there to reboot
Leanne_T
Thanks @Rob602
When this happens do we have any outages showing on the EE Coverage & Network Status Checker, if you select 'check status'?
Rob602
Valued Contributor
Valued Contributor
No outages shown.
The router lights are showing two blue for 5g and connection, and the router page is showing a signal
Leanne_T
Thanks @Rob602
In this case, please call us on 0800 079 8586, our Tech Gurus will run through some troubleshooting with you to get this looked into.
