on 05-07-2024 12:35 PM
Wondering if anyone can help me, I purchased the Xbox series x tech addon and was sent a text with the game card code and pin.
As I use my phone for work stuff as well it is set up to auto delete one time pass codes.
Completely forgot and it deleted the text from EE is there anyway to have it resent
on 05-07-2024 01:44 PM
Hello @JayJ1077
Can you set up the game pass if you go to ee.co.uk/xbox and enter your mobile number?
Hope this helps
