Home phone adaptor plugs useless.
J55C
Got home phone adapters plugs and set them up. All seemed OK but on testing calls the phones don't ring all the time even though the adaptors are connected correctly. Also you can tone dial out to make calls but tone dialling when in a call doesn't work. Found this out when trying to access the menus on 1571 pressing 3 for example to delete messages just does nothing even though you can here the tone by pressing three. Needless to say the phone has now been plugged back into the router directly and the phone adapter plugs unplugged and put somewhere out of the way lol.
Maestro
Maestro
@J55C Posted in the forum as not working before, so you are not the first to say!
