Digital Voice problem
Highpeakblue
Hi my phone was working ok on digital voice connected to my router now when the phone rings when i answer it its dead . When i try to ring out there is no dial tone and the line is silent.Any ideas would be appreciated thanks.
Community Hero
Community Hero
@Highpeakblue 1st step is just to switch the router off, leave for a few minutes and switch it back on, then see if the fault on the phone clears.
Community Hero
Community Hero
Thanks will try it later im out at the min 👍🏻
Thanks Jim all sorted now 👍🏻
