27-06-2023 08:20 PM
I had the same issue, I have done what you advised and it is still not working.
what should I do?
thanks,
georgia
28-06-2023 07:39 AM
Changing your spend cap only takes effect from the next billing date. If you remove it completely, it will be removed straight away. Did you text REMOVE SPEND CAP to 150 to remove it?
