19-05-2022 09:24 PM
I am currently on a 300Mb with BT, but I was looking to switch to 500Mb with EE as I can get it cheaper as a current EE customer plus I can get cashback.
I would assume the switch would be straight forward as they're effectively the same company, but just wanted to check this message on the DSL checker:
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Feed with no anticipated issues.
ONT exists with active service. No spare ports are available. A new ONT may be ordered and will be placed in Waiters list until the network is ready.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
Does this mean there could be a delay between my BT service stopping & EE starting? I work from home so cannot afford any downtime, I'm assuming they will just takeover the existing ONT rather than requiring a spare one?
19-05-2022 09:49 PM
Are you already on FTTP? If you already have an active ONT there they will continue to use that & there should be little downtime as all they have to do is move the cap up from 300 to 500 Meg.
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
19-05-2022 10:00 PM
Yeah, I’m already on FTTP, so shouldn’t be an issue. Thanks for confirming the minimumal downtime.
19-05-2022 10:17 PM
Yes, looks OK.
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
